Home > Technical (L322) > de cat
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
de cat
i have been told that de cating (putting a through pipe in ) is now an mot failure since may this year , i was hoping to present it on gas so no emissions problem . anybody in the know??
Post #488312 7th Sep 2018 6:32pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I don’t believe that LPG concerted petrol engines are especially “clean”:
https://www.nettinc.com/information/emissi...pg-engines
To think we used to breath this cr*p in all the time, but it’s pretty easy to smell the stink from a modern car that’s had its catalyst removed. Please think again Thumbs Up
Post #488316 7th Sep 2018 7:13pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
What he said ^^^ David
Please let me know if my comments upset you, I may wish to upset you again.
Post #488326 7th Sep 2018 8:21pm
As I understand it if a car was fitted with a cat at manufacture and it has been removed it is now an instant mot fail irrespective of fuel type and emissions. It used to be the case that a cat was not legally required as long as the car could meet the emissions standards.
Times have changed for the better.
I personally would not recommend removing a cat, cars really stink without them.
Post #488330 7th Sep 2018 8:44pm
Paul thornton
I removed the cat from my old bmw 530d (basically a td6) and regretted it as it smelt like a tractor!
Post #488335 7th Sep 2018 9:39pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Depends where the cat is fitted. If originally behind a cover (think engine tray) then MoT testers are not permitted to remove covers to undertake the MoT.
It will, however, need to meet the emissions tests.
Post #488349 7th Sep 2018 10:40pm
