Home > Technical (L322) > IID tool reporting Bank 2 MAF sensor zero flow
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Can I ask a favour folks, next time any of you with an IID tool is checking over their SDV8 can you please tell me what the live value for the mass air flow sensor for bank 2 is reading on your car? In fact it might be useful if any TDV8 L322 owners could do the same since it's practically the same engine.
As you can see in the piccy, mine is reporting zero on bank 2. (bank 1 looks fine). For all I know this might just be normal as the IIDTOOL is showing no fault code is being raised in the ECU(s) about it. For all I know this engine only has one MAF sensor that feeds both banks. Laughing
Thought I should check since having the new engine fitted - maybe they forgot to connect a plug somewhere. So far I have to say they did a good job. I thought there would have been a few teething troubles but none (so far.....doh!)
Many thanks.
Fleagle.
Post #488844 13th Sep 2018 8:00pm
Fleagle_UK
Stan, please can you move this to the L322 technical section. - more folk may see it.
Thanks
Post #488983 15th Sep 2018 8:20pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Fleagle I've just been out to my L405 TDV8 and this is what it looks like
 Cheers Ian
Kielder 4x4 Safari
Post #489027 16th Sep 2018 3:59pm
Mikey
Being sequentially turbocharged, the Secondary turbo does not spin all the time, so those readings are completely normal Thumbs Up
Post #489047 16th Sep 2018 8:28pm
Fleagle_UK
Appreciate it. Many thanks guys. Thumbs Up
Post #489051 16th Sep 2018 8:49pm
