Home > For Sale & Wanted > [For Sale] 02-05 L322, ULF, Steering wheel hub, Resler etc
Page 2 of 3 <123>
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Bump, going to ebay soon, offers considered Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #495811 17th Nov 2018 4:02pm
Bushy30
Bump, some ideal Xmas pressies in here Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #497647 5th Dec 2018 12:34pm
Bushy30
bump up Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #501521 14th Jan 2019 4:52pm
Bushy30
Surely someone wants some of this? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #503233 29th Jan 2019 7:17pm
Bushy30
Bump Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506918 1st Mar 2019 8:20pm
Mr Fudge
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Just bought a 2004 TD6, which doesn't have bluetooth. Still doing some research on this but could be interested. Like you I'm near Oxford.
Post #506952 2nd Mar 2019 9:44am
Bushy30
Hi Mr Fudge,
If you take a picture of the rear left cubby I'll be able to advise what's required
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506995 2nd Mar 2019 1:55pm
Mr Fudge
Will do, many thanks.
Post #507000 2nd Mar 2019 3:03pm
Mr Fudge
Here they are:
Post #507006 2nd Mar 2019 3:44pm
Bushy30
You've definitely got a Bluetooth module connected, silver box in front of the black box rearmost of all the toys.
Can't quite identify which one it is though. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #507035 2nd Mar 2019 7:31pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
The reverse cam, forgive a newbie owner here, but would this fit an 2002 RR with TV , switch the screen when reverse engaged and some fitting instructions ?
Thanks
Post #507070 2nd Mar 2019 10:41pm
Bushy30
Hi BMG,
Yes, but not out of the box, you need to do some mods to wiring etc
Previous: -
Post #507075 2nd Mar 2019 11:07pm
BMG
If there is some instructions on fitting this, I'll take it.
Post #507078 2nd Mar 2019 11:19pm
Bushy30
There are no instruction, it's an aftermarket camera in a number plate, it presents RCA connectors which will need modding to fit the aux in of your BM54, you can also pick up a feed that will switch to the aux in when activated.
So folk take a feed from the reversing lights, to the camera (so it's only powered when reverse is selected, and also use that to auto switch to the aux in feed.
Hope that helps
Previous: -
Post #507081 2nd Mar 2019 11:37pm
Bushy30
bump Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #509054 18th Mar 2019 11:51am
Page 2 of 3 <123>
