![]() | Home > Technical (L322) > Tyre wear |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3953 ![]() ![]() ![]() |
I've had my 4 wheel alignment and tracking done a few times but I keep getting wear on the outer edge of the rear tyres (one worse than the other).
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
I had the same as you V8Noise -- one was though to the steel braid, from the outside looking in all seemed good with in excess of 5mm tread on both Current: 2011 FFRR Vogue SE 4.4 TDV8
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I would suggest replacing upper and lower rear hub rose joints along with the respective bolts and washers. The upper joints have eccentric washers on them that adjust the camber angle - replace these, along with the bolts so the camber can be adjusted easily, then get the rear aligned again. |
