![]() | Home > In Car Electronics (L322) > anyone near stoke on trent |
| jk3528 Member Since: 28 Sep 2018 Location: stoke on trent Posts: 46
is there anyone near stoke on trent with a l322 from about 2003 that will let me plug in my audio bits to see if I can work out which ones are ok and which arnt
Could be what radio setup have you got? |
| gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213
Have you tried cleaning up all the connections to remove any gunk etc from any previous water ingress? |
Yes but with the IID tool it can’t find any of them |
If you've cleaned up all the connections properly, have you tried looking to see if any of the pins have got bent or broken over time. I recently had my screen go, there was a missing pin in the connector into the tv module. Swapped the unit out for £30 and it's working fine now. It could be some damage to one of the boards that you can't see without taking them apart but there's every chance there'll be a fault you can spot. Don't think you'll find anything with the IID, mine didn't flag anything |
Checked the boards taken the covers off
| Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409
Standard vogue with Satnav. Current:
This has the screen with cassette behind it
Yes by all means, sounds exactly the same as mine. Current:
