![]() | Home > Technical (L322) > Battery AGM or not |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Keith,
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I have an 020 in my 2011 , its very tight and i trimmed off a bit of the bottom plastic on the battery ro facilitate the fitting. The 2011 uses an AGM normally because the alternator is ' intelligent ' and varies the charge. It keeps the battery at 80% and so it may not be suitable for a normal battery. All of my info is from the net and im far from an expert. 2015 4.4 AB
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Thanks for the replies. Have been reading what I can I am not certain mine should have an AGM anyway.
Dolph,
Hi , i had one in my 2007 as well, im sure others have fitted 020s in theirs too. It is tight but a bit of trimming amd robert is your dads brother |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
I ran an odyssey pc1500 in my 2010 3.6 for two years no problem. Cheers
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Keith, your 2010 had a mod done by JLR to the charging system and at that point they changed the batteries to AGM... I believe with the Mod you would need to run an AGM sir... |
Craig
