Home > Maintenance & Mods (L322) > Heated seat not working
Andy
My drivers seat has stopped working. I get the two lights on the button, then they go out.
The question I want to ask is: Do I need to remove the whole seat or can I remove just the seat base whilst the seat is still bolted in?
Before I do either, I intend to "bell" the wires for continuity to confirm it is a broken circuit. Which wires supply the element on the plug underneath the seat?
Many Thanks In advance
Post #493369 23rd Oct 2018 4:47pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi Andy, much easier to remove seat - its not that difficult tbh. The wires are buried at the back and the rear cover has to come off as well so easier to do on a bench or table.
I did a write up which i in the wiki if it helps.
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #493373 23rd Oct 2018 5:00pm
Harlequin
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Paul if you fancy doing mine please let me know, lol Laughing
I have the same problem.....,!
And i am local! Rolling with laughter
Post #493402 23rd Oct 2018 9:32pm
