Home > Maintenance & Mods (L322) > Service every 6 months? 3.6 TDV8
Hitby
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
My 2008 Vogue was serviced when I bought it last year at 110k, I expected it to last until November but the service interval warning came on for an inspection in May (6 months later). I had it serviced and it's just popped up again for November. I've only done 8k miles in total and only 2.5k since the service in May.
Surely this can't be right can it?
Post #493431 24th Oct 2018 8:51am
I would imagine the service reset was not carried out... simply have it reset then make sure you have the next service carried out 12months after your last service, keeping a close eye on the service agent resetting it at that point...
Only other possibility is your service interval meter has been set to the arduous use plan!!! This means you live in a desert or at the South Pole!!! And the car would require more frequent maintenance.
Not sure the North East is cold enough to warrant the above though sir Laughing Thumbs Up
Post #493436 24th Oct 2018 10:54am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Interestingly my S/c, which was serviced in January and the service re-set was definitely done ( I was there when he did it) has this month started to tell me inspection due 10/2018.
Go figure. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #493440 24th Oct 2018 11:43am
How many miles has it covered since January?
Post #493443 24th Oct 2018 11:59am
dingg1
thats nowt , mine tells me inspection due 2004
car built 2007
back to the future mobile
Post #493444 24th Oct 2018 12:00pm
V8Noise
About 2000 Craig. It does few miles, hence the gas guzzler. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #493446 24th Oct 2018 12:09pm
