Home > Technical (L322) > Heater So So.
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Heater So So.
Ok folks here's my heater issues.
Heater control lights up, as you rotate the knob & the fan speed increases, although Not really that high on maximum & the heat is not that hot on maximum.
AC is fine. I can hear the blend control switching from cold to hot & vice- versa. So my thinking is that the FSR is okay & should be looking at the control valve.
Before I start ripping parts out, has anyone else come across this scenario?.
Post #493505 24th Oct 2018 8:09pm
