Home > Technical (L322) > Fuel Burning Heater - Which Fob ?
AJGalaxy2012
Ive just checked in my boot and I do have the T91 receiver / controller, which keyfob do I need to communicate with it?
Ive seen several conflicting posts, advice and part number for the right one would be appreciated.
Kind Regards - AJG BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #493994 29th Oct 2018 3:01pm
phn
Hi I have a 2007 TDv8 and the fob for the fuel burning heater is shown in the attached picture.
To be honest I have never used it as the FBH has never worked on my car, but that is what I was told this remote was for when I bought the car!
Hope it helps,
Philip.
Post #494010 29th Oct 2018 3:56pm
AJGalaxy2012
Thanks Phil, I believe there are two different receivers T90 and t(1, do you happen to know which one yours is?
Post #494017 29th Oct 2018 4:23pm
phn
Hi sorry, I don't know off hand what the model this remote is - will have a look when I get back home at the end of this week.
Post #494025 29th Oct 2018 5:05pm
DMRR
That's a T90 - I can confirm a T90 works on a 2006 TDV8 and 2009 TDV8 - as I have used same remote on both Very Happy Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #494034 29th Oct 2018 5:41pm
AJGalaxy2012
I need it for a 2012 with the t91 receiver. BMW i3 Electric Car
Post #494045 29th Oct 2018 6:31pm
dolph34
Both work with a 2007 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #494061 29th Oct 2018 8:16pm
philip600
The fob for my 2012 Westminster doesn't look like that, it's similar but the antenna bit is smaller. Not sure what type it is or receiver I have. Hopefully someone more knowledgable will be along with the answer.
Phil
Post #494065 29th Oct 2018 8:31pm
mjdronfield
This is for my 2011.... should be the same....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #494075 29th Oct 2018 9:49pm
AJGalaxy2012
Thanks for that I'll try and find one. BMW i3 Electric Car
Post #494079 29th Oct 2018 10:05pm
mjdronfield
I think the part number is lr027493. T91? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #494085 29th Oct 2018 10:24pm
philip600
Unnecessary quote removed
That's the one I have for mine 😊
Post #494088 29th Oct 2018 10:33pm
Lavazza
I tried to activate my FBH remotely this morning, but to my surprise, it set the alarm off! No idea why.
Have subsequently tried it and seemed OK; but I get up at 0530, so it's an unsociable hour for 'alarm issues'.
Any ideas what's happening?
EDIT: 30 Oct, tried it again this morning and worked fine, which is good, but I can't be doing with intermittent faults, so will get it checked by LR.
Post #494091 29th Oct 2018 10:58pm
