Home > Maintenance & Mods (L322) > Another water leak
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Another water leak
I've traced this to where the coolant level sensor fits into the base of the expansion tank (M62 V8 engine). I have't taken it out yet, but is there a simple to replace o ring seal there or do you have to replace the whole sensor? Thanks. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #495146 10th Nov 2018 12:00pm
alistairh
No part listed for o ring so must come with sensor .they aren’t expensive tbh .
Post #495150 10th Nov 2018 12:51pm
alistairh
https://www.island-4x4.co.uk/sensor-coolan...31160.html
Post #495151 10th Nov 2018 12:56pm
rvbush
Blimey, no they're not expensive are they! Just assumed they'd be silly price. I'll get one and see if the leak stops.
Thanks all. Drives:
Post #495157 10th Nov 2018 2:02pm
wayneg
There is no O ring for the sensor as there is no fluid at that join. The sensor is a magnetic reed switch and can be removed with the tank full. The tank splitting at the seam is the most likely culprit 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #495163 10th Nov 2018 2:54pm
rvbush
Hmm, that's interesting. There is definitely fluid dripping from the bottom of the level sensor. Maybe it has sprung a leak in the header tank although this one isn't that old (the old one failed spectacularly!). I'll see how it goes.
Thanks again. Drives:
Post #495164 10th Nov 2018 3:18pm
