Home > Technical (L322) > Suspension problems after car jacked up on one corner.
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I had the cv joint replaced on my 2003 range rover. Ever since then the rear suspension has been raised, the front lowered with the passenger side (which was the side jacked up) on the bump stops.
Ive plugged it in and its showing a fault with the left front sensor, but it was all fine before the work was done.
is there anything i should be doing to test this?
Diagnostic info is:
Front left voltage 15.56 (all of the others are 2-4)
Reservoir pressure 11.57 bar
Front left bellows valve off
Any help appreciated as i need the car running for monday when i go to work Sad
Post #495170 10th Nov 2018 4:30pm
cass
Have a look at the front left height sensor and compare it to the others.
It is possible for the sensor “arm” to flip around and end up 180 degrees out when it is jacked up.
This sounds confusing but if you look at it you will probably see what I mean.
Post #495171 10th Nov 2018 5:07pm
mjdronfield
+1 for the above. At least as the first thing to check.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #495173 10th Nov 2018 5:45pm
Danbhardy
didn't even need to look at the others, your a genius! it was the small plastic arm connecting the long arm and the sensor unit was pointing the wrong way, 90 degrees!!
Post #495174 10th Nov 2018 5:47pm
mjdronfield
Result. Nice one.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #495175 10th Nov 2018 6:20pm
