![]() | Home > Technical (L322) > Very strange air suspension issue [Now Fixed] |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
1. The fault code in the LCM is set when there is a fault in the EAS, so will need clearing
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 329 ![]() ![]() ![]() |
Thanks, compressor will run when told and maintains the tank pressure at 11.8 bar so that appears ok.
I can't believe it but I've cured it, I started looking at the calibration to see if I could teach it but to be honest I wasn't particularly sure so I left it alone.
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Jobs a good un. How's life with the fatty? 2003 Range Rover Vogue 4.4 on Gas
I’ve been meaning to email you actually!
