![]() | Home > Technical (L405) > Fake main beam headlights.. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Sorry, that’s really lazy man.. go find it yourself.. |
Dixy here you go sir...
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1120 ![]() ![]() |
Thanks Craig.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Same for me, the bi-xenons on my old L322 were in a different class to the ones on my L405, one thing I really miss from the old RR. Steve
Fancied a light bar on my 405 so.... Here's the results |
Wired it from a standard old school 4 pin relay sir... |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I don't suppose you would mind doing some kind of guide?
There are many guides of the net for wiring up relays sir. The only thing i added was a switch to the earth wire so i could turn it off when i didn't want it working every time i used full beam! Fog etc etc
Thank you |
Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 17 ![]() ![]() ![]() |
As I have a LHD there may of course be differences in the wiring loom, but could you please provide me with a more specific point for a good +12V source for driving the lightbar? I have removed both air boxes and looked around but cannot see an obvious candidate. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Just to explain a little what a relay is/ does.
NP. I am aware of that and have an extra wiring loom with relay, fuse, switch and deutsch quick connector to the lightbar. I will use the high beam shutter signal for relay control.
The safest way is to disconnect the plug fro your headlamp and meter out which pin supplies the high beam and use that as your trigger wire, then use the jump start post (underneath is a 13mm bolt head) for the battery + and next to the headlamp are several earth points sir… 👍 |
Ok, thanks Craig.
