Home > Maintenance & Mods (L322) > Dealers' suspension tales
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
as follow up on my previous post, my Indy took my car to the RR dealer, because he couldn't find a solution to the suspension problem. Now the dealer told him one can not replace just one side, you have to replace two or all four. They also found out that when they turn the steering wheel to the right all four suspension airbags empty themselves and the body is on it's wheels. So there must be a leak in my opinion. My indy at the end of his wits, the dealer trying to get me change all four.... Any idea's PLEASE Bow down Bow down HELP
Post #496111 20th Nov 2018 8:48pm
Link to your other post:
http://www.fullfatrr.com/forum/topic49323.html
Never heard that from a dealer before Evil or Very Mad (yes replace both sides / as a pair on the front because of the shock absorber but not for air suspension reasons.)
Your indie needs to do some detective work:
Compressor functioning correctly
Air reservoir holding pressure at correct value
Leaks in pipework / valves /connections (to new bag?)
Leaks in other airbag/s (or new one!)
Height sensors all correct, working and in correct position (e.g. not 180 degrees out)
Decent tool for calibration of ride heights and resetting/clearing of faults / config (you mentioned a "Pro Tool", what Pro Tool ???) .
Post #496113 20th Nov 2018 8:56pm
Robert
Thanks Joe.
compressor OK at 12
seem to be no leaks in airbags
have replaced relay (they had a C1A000 code)
height sensors are OK according to software,
will ask him tomorrow to check pipework/connection on the new airbag
The pro tool I've seen there is a programm on their garage computer where they can enter individual ride height and all the rest I've seen on the OBD tool one of the sponsors on here is selling. Don't know what the name is of their tool.
Post #496116 20th Nov 2018 9:07pm
GraemeS
Australia
A leak wont cause a sudden drop to the bump-stops. However failure of more than 1 height sensor will trigger an immediate drop to the bump-stops, as will implausible articulation derived from all 4 height sensors which could be caused by a height sensor producing an apparently valid signal.
Post #496120 20th Nov 2018 9:25pm
Robert
Thanks greameS,
do you know how one can check an apperently faulty height sensor, that gives a valid signal?
Post #496122 20th Nov 2018 9:38pm
Just FYI on my 12 the dealer replaced one side only when an airbag went.
From a shock absorber point of view they should generally be replaced in pairs, but from and airbag POV then just fix the bust one.
Made the argument to my dealer when they replaced my burst bag, but was told that there was no need to do the pair..... There is nothing that can't be fixed with a hammer😜😜
Post #496125 20th Nov 2018 9:57pm
^^^ does depend on the age of the vehicle
I'm with Graeme S on this, does sound like a height sensor issue of some kind .
Post #496128 20th Nov 2018 10:09pm
GraemeS
Australia
The implausible fault wont indicate which sensor otherwise the system would simply ignore that sensor. If turning to hard lock causes the dropping and assuming that no fault codes exist for 2 specific failing sensors then monitoring the actual height values with a diagnostic tool as lock is slowly increased might (should?) show a corner changing height significantly when the others don't change much.
Post #496143 21st Nov 2018 4:16am
Robert
Goodmorning,
Thanks guys, I'll go down to the garage and have them search for a leak in the tubes and tell them to look in to the height sensor, keep you updated.
Post #496153 21st Nov 2018 9:29am
