Home > Maintenance & Mods (L322) > IID tool - LED reserve light upgrade
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Afternoon all,
Changed the reverse lights over to the nice bright ones that Bushy has supplied, and all is well (and bright) again. I'm aware that I can turn off that annoying flash check on start up using my IID, but within the lighting ECU there are a million options, and I don't want to go faffing about. Does anybody know which specific option deactivates the light check, and also are there any possible issues with switching it off?
Cheers Thumbs Up
Post #497567 4th Dec 2018 3:40pm
do you get an error then?
if you do then look in the LCM menu...
Post #497568 4th Dec 2018 3:45pm
SandySix
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
To quote Stan himself in reply to my question a while back...
" its in the LCM ...cold is on start up and hot whilst engine running..."
Turned mine off... no ill effects.. and no flashing either Very Happy
Post #497569 4th Dec 2018 3:54pm
gj88
No, no error, the flashing is just annoying on each start up. CM - Reverse Lights in the LCU does seem to have solved it though, so thank you both
Post #497577 4th Dec 2018 5:52pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
It is interesting, I've done nothing with mine but don't seem to experience the issue! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #497578 4th Dec 2018 5:55pm
nor do i, maybe its year related..
Post #497580 4th Dec 2018 6:27pm
gj88
Could well be. I'd read about the 'issue' before buying the lights, so wasn't too perturbed if nothing could be done. To be honest you're probably unlikely to notice it unless you're looking for it, it does a few quick flashes as you turn the key, so unless it's particularly dark and you're looking in the mirror I'm not sure you'd notice. Thanks again though, one of those tiny annoyances fixed, onto the next!
Post #497581 4th Dec 2018 6:35pm
