Having an issue with the electric windows on the ole fat one!
Rear passenger window goes down on its own if you have the master button on the drivers side in the on position but will then not respond to any buttons either the rear one or the front master buttons? If I push the window disable button to lock windows on the front drivers door it will work with either front or rear buttons?? Thought it may be a faulty master switch pack so swapped it for another but it hasn’t cured the problem😕 anyone any ideas??
