Home > Technical (L322) > phone system
paddybyrne1
United Kingdom 2006 Range Rover Vogue Td6 Java Black
phone system
Hello......may sound like a silly question but here goes.
I don't have a handset in my car but have the phone kit installed, I am in the midst of buying a phone for it, where does the SIM card go? Is it in the back of the phone or somewhere else?
Thanks,
Pat. Pat
Post #52489 2nd Mar 2011 1:12pm
in the phone pat....i've got the adaptor as well and was thinking of buying a cradle and phone ...i for one would like to know how you get on.. Wink ... - .- -.
Post #52497 2nd Mar 2011 1:24pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
is this the 'cradle' that fits the contacts in the centre cubby box?
Nokia i gather?
apart from a charging facility does it offer any advantages over bluetooth?
Post #52504 2nd Mar 2011 1:32pm
thats the one, the cradle takes nokia [mainly] and siemens phones..
advantage is that your contacts will be shown on the screen...you can get this with bluetooth but you need a dealer software upgrade for that.. ... - .- -.
Post #52511 2nd Mar 2011 1:40pm
nick h
thanks Stan Smile
seen them on fleabay - mostly quoted for Nokia 6230
Post #52517 2nd Mar 2011 1:46pm
I up graded my Bluetooth to use my i-Phone so now have a brand new Nokia 6320i and Land Rover cradle going spare PM me if you want it. 2008 MY Supercharged
Post #52591 2nd Mar 2011 6:24pm
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
does your iphone now connect automatically and allow the use of the phone book???
Post #52594 2nd Mar 2011 7:48pm
JustinP
My iPhone 4 connects without intervention and I can see the phone book contacts.
However it's not perfect, for contacts with multiple numbers it only displays the home number and i cant see how to select mobile or work etc, so I still tend to dial from the handset.
Mostly the incoming caller name is displayed, but not always Sad
Post #52595 2nd Mar 2011 8:07pm
algt2
I love the way it’s such a random event with the iphone sometimes it does everything right and you get the full use, other times it doesn’t even connect, add’s an air of suspense on every journey Laughing
Post #52596 2nd Mar 2011 8:12pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
For those with the BT iPhone 4 does your phone hang up when you press the red phone icon on the RR central display? Everything works on mine but hanging up the call which I can only do from the handset which is annoying. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #52613 2nd Mar 2011 10:28pm
JustinP
Works for me Cool
Post #52616 2nd Mar 2011 10:47pm
Yes every time and with phone book too although with the usual one number per name. 2008 MY Supercharged
Post #52629 3rd Mar 2011 8:28am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Works fine on mine but just ocassionally I have to re-pair the car and my i-phone4. I have a Parrot system (http://www.parrotshopping.com/uk/p_parrot_item.aspx?i=183253 ) in my Defender and that works first time every time regardless how long it is since the Defender was last used. The only problems I have with the Parrot is that when the iPhone is hooked up to the connector (rather than using B/T) and the phone is then put inside the cubby behind the head plate the unit gets very warm and also when the phone is searching for a network I get that awful pulsing noise over the speakers over the top of whatever I am listening to 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #52651 3rd Mar 2011 11:17am
One thing I have found with Bluetooth and my I-Phone 4 is you must approach the car with Bluetooth on and not turn it on once you have started the engin , If I do for get I find I have to turn my Venture Cam on and off to get the phone to connect . 2008 MY Supercharged
Post #52678 3rd Mar 2011 2:52pm
algt2
good to know, thanks for that, think I’ll get the software upgrade and see how it goes! Thumbs Up
Post #52729 3rd Mar 2011 5:25pm
