![]() | Home > Maintenance & Mods (L322) > results of new suspension parts |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Did they reuse the washer on the upper ball joint of the anti roll bar links as apparently without this can cause a clunk. Current 2007 TDV8 Vogue Buckingham Blue |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
good point. they took the car back in and checked everything so i assume they got it right. i will check it next dry day. |
Another thought could be something catching the brake disc shield if its at a weird angle when it happens if thats been disturbed when replacing the parts as well. Or a nut just isnt tight enough on that side. Hope you get to the bottom of it as its a real pain and seems some people spend years chasing down a clunk! Current 2007 TDV8 Vogue Buckingham Blue |
very annoying considering it DIDNT clonk on that side when i took it in still wearing the old parts and it DID clonk when i got it back fitted with the new ones! |
so, the indy got the car back and, given that thye'd just fitted all new bushes on both sides decided it must be the strut so tried a new strut - still clonked.
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Moog's had a steep decline in the quality of their parts.
