Home > Technical (L322) > Strut hex key
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Strut hex key
Hi there
Does anyone know what size hex key is needed for the top (harmonic?) damper on a 2006 SC? I have the strut off to replace the air spring but hit a stumbling block as my largest key is 12mm. It looks like it will be a 13 or 14 mm?
Thanks
Mark
Post #499155 19th Dec 2018 2:30pm
Not sure of the size but, buy yourself one of these:
Will also come in handy when changing diff and gearbox oil, also good for Audi hub bolts Wink .
Post #499168 19th Dec 2018 3:14pm
mandelbug
Thanks Joe will look at getting a set
Post #499176 19th Dec 2018 3:43pm
mandelbug
If anyone else wonders, it's 14mm, and a set of drain plug keys will do it Smile
Post #499188 19th Dec 2018 7:04pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Dirt cheap at screw fix. I think I oId something like £7 for a set.
Jim
Post #499196 19th Dec 2018 7:43pm
