Home > Maintenance & Mods (L322) > Wheel Bearing replacement |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Its probably wheel bearing time. Front left. I see these look like a real pain to change. Are they even worth finding the specialized LR tools to do this? What kind of price should I expect per axle from a shop? I figure if one is going I should be prepared for others to go soon. Plus my rear brake shield has rusted through the shoe retaining pin hole. |
29th Dec 2018 5:44am |
Can be a PItA, to do the bearing, I got my local mechanic to do mine and he was swearing and that was with a new hub assembly to fit in the process. Unless you have a press then I would send it to a garage..... There is nothing that can't be fixed with a hammer๐๐
29th Dec 2018 11:19am |
Thank folks, rik unfortunately these years are not the kind you can buy a hub and bearing pre-pressed.
2nd Jan 2019 1:02am |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
You could by a second hand one ready to fit cheap as chips ๐ |
3rd Jan 2019 3:56pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Not had to do the bearings yet but just had both rear brake shields replaced on my TD6 - mechanic slitted the shields with a slitter disc on an angle grinder and bent them slightly to fit around the axle - job done and not expensive either ! Before this I was looking at the split shields from the states at 500+ ! |
5th Jan 2019 2:21pm |
