Home > Technical (L322) > Engine light :( EGR related fault code P0406-22
rar110
Hi
yesterday and today I have started to get the engine light on start up.
IID Tool indicates fault code P0406-22 EGR "sensor A circuit hight - General signal failure - signal amplitude>maximum".
Both EGRs have been unplugged for about 2 years after I fitted emulators. The EGRs are disabled in the closed position.
Any advice on this fault would be appreciated.
thanks, Peter ______________________________
Post #500056 30th Dec 2018 10:14am
Weegie
Have you checked the manifold for cracks? John
GAP iiD BT-Sold
Post #500071 30th Dec 2018 11:44am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Emulator fault!! 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #500090 30th Dec 2018 4:03pm
rar110
Tkanks for the replies. I’ll swap the emulators and see if the fault moves to the other EGR. ______________________________
Post #500127 30th Dec 2018 9:01pm
rar110
Well I’m not sure about a faulty emulator.
I ran the IID tool again and fault appeared as before. I swapped them over, ran the IID tool and it bought up the same fault, initially. Then cleared the fault and now fault doesn’t return.
I’m thinking another intermittent fault. ______________________________
Post #500141 30th Dec 2018 11:19pm
rar110
Posted too soon.
The original fault code came up, cleared that. Then a new fault code appeared to replace the old code.
“P140B-22 (2E) Exhaust gas recirculation sensor C - circuit high - General signal failure - signal amplitude>maximum”
Cleared that and faults hon for now. ______________________________
Post #500143 30th Dec 2018 11:34pm
Grofus
Id get the Egrs mapped out mate.
Permanent result and forget them.
Best thing I did. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #500147 31st Dec 2018 12:51am
rar110
I’m starting think this is just a case of gunked up sensors. May need to take out pollen filter housing for a look around. ______________________________
Post #500230 1st Jan 2019 1:39am
