Home > Maintenance & Mods (L322) > Just Passed MOT but.... |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 220 |
It isn’t as simple as the latches on the lower tailgate needing lubricating is it. |
5th Jan 2019 9:42am |
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 |
I don't know to be honest hadn't thought of that but thanks for the suggestion 2003 Vogue 4.4 petrol, silver 126k on clock when I got her |
5th Jan 2019 9:50am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
I often used to move the black plastic bits on the boot latch by hand before closing it on my old one. Lubrication worked for a while but I just got used to doing it manually. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
5th Jan 2019 9:51am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
+1 for Jamiehol's latches. My lower doesn't lock sometimes on the offside, needs relasing and shutting "firmly". That may be the adjustment, if any, and I'll feed back when I look further into it. See if the locks in the 'gate operate by "closing" them using a screwdriver or similar. If they don't cycle, it may be they need taking apart and cleaning/repairing or replacing.
5th Jan 2019 10:24am |
Northern lad, search is your friend, try tailgate latches. Couple of posts in that :
5th Jan 2019 10:35am |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2543 |
Steve, my lower tailgate didn't shut on my last one or now this one so I just flick the black plastic bit as mentioned before shutting. Right hand side off the tailgate inside at the latch. No idea why they do it though? |
5th Jan 2019 10:40am |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Had the same thing recently. As above, lifting the black clips up will allow it to shut, but a quick squirt of WD40 in both sides cured it for me |
5th Jan 2019 1:50pm |
gj88, did you apply the WD40 to the latch bit by the black clips? thanks |
5th Jan 2019 6:37pm |
Ashamedly I gave almost everything in my eye line a good blast, but yes, the mechanism, the black clips, anywhere I could see a gap in I gave a squirt, been great since |
5th Jan 2019 6:58pm |
Westminster Member Since: 23 Mar 2017 Location: UK Posts: 128 |
Any link for the cheap battery? |
7th Jan 2019 11:59am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
I can’t match his £35, but this was the cheapest one I found with a 5year warranty and free next day delivery.
7th Jan 2019 12:36pm |
Hi All
8th Jan 2019 8:13am |
Hi All
10th Jan 2019 8:17am |
