Home > Technical (L322) > Fuel injector numbering
ptaroni
Does anybody know the injector numbers? I know the cylinder order but need to know which is injector 2 as im sure its done in firing order. Hopefully someone will clarify this for me Smile 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500791 6th Jan 2019 8:51pm
Injector 2 is Injector 2 (based upon cylinder numbers, 1 being at the front of the engine)
Firing order. 1 - 5 - 3 - 6 - 2 - 4 .
Post #500792 6th Jan 2019 9:36pm
ptaroni
On a tdv8? 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500794 6th Jan 2019 9:38pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Numbering as below.
Cylinders 1 & 5 are at the front (fan end or NDE) cylinders 4 & 8 are at the gearbox end or DE.
4. 8
3. 7
2. 6
1. 5
Post #500795 6th Jan 2019 10:21pm
ptaroni
I know the cylinder numbering but i think the injector numbering is different . Ive seen on the disco forums the cylinder and injector numbers are different so assume that it would be the same. 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500796 6th Jan 2019 10:24pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
On my 2008 L322 TDV8, the injector wiring loom was numbered at the injector connector end. Right bank was 1-4 from front to rear.
Post #500810 6th Jan 2019 11:31pm
gilesharrison
Post #500811 6th Jan 2019 11:32pm
Don't know why I thought TD6 Embarassed .
Post #500814 6th Jan 2019 11:46pm
ptaroni
This is what i mean.... 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #500815 6th Jan 2019 11:50pm
