Home > Technical (L322) > Check Dip Beam
Fish13
Check Dip Beam
Hi,
Did a search and I know this has been covered before but I didn't quite find the answer, so excuse the post!
I had 'check dip beam' come on a couple of weeks ago, and the passenger/nearside dip bulb wasn't working. Turned car off and on again and it worked fine. Did this for a while until the dip bulb just didn't light up anymore.
I bought some Osram bulbs from Powerbulbs online and duly changed both dip bulbs and it worked great......for a day. Turned off car at night last night, no problem at all, turned car on this morning, no passenger side dip light and the 'check dip beam' message again! Turning off and on again/clearing faults with icarsoft etc did nothing.
I bought a replacement bulb to keep me legal as I have to drive this evening, so will change it out, but this will get expensive quick - can someone point to what's wrong, and what part numbers etc I might need to fix the fault properly?
Cheers,
Fish.
Post #500840 7th Jan 2019 12:04pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
It would be helpful to know which model of Range Rover and type of bulb........ Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #500842 7th Jan 2019 12:18pm
Fish13
Sorry!
It's a 2003 3.0 diesel HSE.
Bulb that was changed was 'Osram D2S 35w 66040' - this was the dip beam bulb for the passenger/nearside of the car (although I changed both sides initially.
Worked fine last yesterday and last night, turned car off, back on again this morning and no light and the 'check dip beam' is back.
Cheers,
Fish.
Post #500844 7th Jan 2019 12:25pm
i guess it could be the ballast/igniter failing..
Post #500845 7th Jan 2019 12:25pm
Fish13
Thanks Stan,
Is there a fix for this, or if not, a replacement part number?
It's a 2003 model.
Cheers,
Fish.
Post #500846 7th Jan 2019 12:31pm
Have the bulbs actually failed. I would check for possibly corroded contacts in the bulb holder. You could also put the "failed "
bulbs in the other headlight and see what happens.
Post #500847 7th Jan 2019 12:33pm
fish, i sold one on ebay many years ago so i'm sure there will be some there..
Post #500850 7th Jan 2019 12:44pm
Fish13
Thanks guys,
I just put the new bulb in and it's working again (for now). When I first turned on the lights after fitting, neither dip beam bulb came on - turned the lights on and off again and both came on?
I'll see if chap you mention on here has a ballast as I'm sure this bulb won't last long!
Cheers,
Fish
Post #500863 7th Jan 2019 4:07pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Are they factory Xenon lights? Not all the HSE's had factory fit Xenons on that year, so its possible that your ballast units are aftermarket which may confuse further Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #500887 7th Jan 2019 9:36pm
Balloonengineer
If its 35w then its xenon, otherwise it would be 55w if it was halogen.
I had this and it was the ballast. New ones on ebay for £28, its not worth buying a second hand one
I did a write up a while back if you search
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #500898 8th Jan 2019 12:35am
Fish13
Just to update on this.....
Fixed this yesterday and it was the igniter in the end - I bought the parts off 'an online auction site' and got 2nd time lucky. The first igniter the wires between the unit and the bulb holder were too short (despite seller saying they would fit) so had to order another one.
I changed the ballast too whilst I was at it.
Headlight unit to come out was easy enough (getting back onto the runners at the bottom not so much!) but the headlight strip itself I found quite tricky, and you have to do this to get the ignitor out.
If of help to anyone, the parts numbers for my 2003 TD6 HSE were:
Ignitor - 1 307 329 059
Ballast - 1 307 329 074
The last 3 digits on the ignitor are what caught me out, so unless it's the above, the wires are different lengths and won't fit.
Cheers,
Fish.
Post #516055 21st May 2019 9:03am
