Home > Technical (L322) > Hard reset
nearlee
Wales
Hard reset
Not sure if it's possible to do a hard reset on the ffrr.
Did it a few times when I had my d3, if it is possible then is the process the same as the disco? Remember:- amateurs built the ark
Proffesionals built the titanic
Post #500930 8th Jan 2019 3:02pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
If you mean get all ECUs to reset to their current programming, then the following worked for me.
With the ignition OFF!
1. disconnect both battery leads, negative first - wait 10 mins;
2. touch the + and - leads together for 10 seconds. wait 10 mins;
3. reconnect leads, negative last - wait 10 mins.
4. all ECUs should have reset and be ready to go.
No doubt there is a JLR approved procedure somewhere but it cleared an obscure anomaly on mine.
Note: this is not the same as resetting to factory defaults, which requires IID tool or similar. Forty years of progress. 1972-2012
Post #500958 8th Jan 2019 8:25pm
nearlee
Wales
Cheers arbuckle
That sounds about right very similar to the disco,. Remember:- amateurs built the ark
Post #500959 8th Jan 2019 8:28pm
holidaychicken
What year do you have ?
Post #500964 8th Jan 2019 9:48pm
nearlee
Wales
It's an 07 tdv8 Remember:- amateurs built the ark
Post #500985 9th Jan 2019 7:28am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Get yourself a IID tool Lee, great bit of kit! Even I can do things with it!
Hope you’re well
David 2014 vogue se
Post #500989 9th Jan 2019 10:24am
holidaychicken
Just wondered on the year as the earlier ones up to 05, you have to wait for the satnav light to go off before disconnecting the battery or it can die. I always did this but the other day i thought i wouldn't bother as it was probably just a precaution - my satnav died but luckily after a lot of messing about it came back to life.
Post #501035 9th Jan 2019 8:12pm
