Home > Maintenance & Mods (L322) > L322 front strut |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 137 |
It seems that one of mine L322 front strut have some internal problems due to the noise it makes as hiting road imperfections.
9th Jan 2019 2:37pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
most noises at the front are caused by drop links or ball joints - check those first.
9th Jan 2019 5:41pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
This was my earlier thread
9th Jan 2019 5:43pm |
second what dexio says, i cant see why the actual strut would cause banging, most likley drop link or ball joints.
9th Jan 2019 5:45pm |
i forgot to say that I've recently removed the air spring off a strut and cut it open.
9th Jan 2019 5:51pm |
Some months ago I've replaced all the suspension arms, ball joints and sway bar links. The noise appears to be from the suspension strut its like a discharged or faulty shock. On the anual inspection (your MOT) wich where in December, the technician (correct name?) told me that he found nothing wrong.
9th Jan 2019 7:19pm |
in the picture above the big metal circular part is the stop for the upper part of the yellow bump stop. the other parts are only concerned with keeping the air in the bag so nothing in the picture will cause a noise you can hear.
9th Jan 2019 8:17pm |
Hi Dexion
10th Jan 2019 2:35pm |
