Home > Maintenance & Mods (L322) > 6 Pot Brembos -Pads and measuring discs (thickness) - tips?
Page 3 of 3 <123
GGDR
Thanks Mike, yes I'm cautious about the pins, having read all the reports...
I think yours is a good idea.
Any preferences on kind of grease?
. Cheers, Greg
Post #501528 14th Jan 2019 5:15pm
GGDR
Also need a drift.
Anybody know the correct size I should order?
. Cheers, Greg
Post #501530 14th Jan 2019 5:24pm
Baltic Blue
Greg,
I bought a set of these parallel punches, which worked perfectly well. Thumbs Up
Post #501548 14th Jan 2019 6:26pm
GGDR
Thx Mike! Set ordered! Greenstuff pads ordered today too. Boy am I looking forward to the low dust everybody raves about. I clean my wheels twice a week at the moment. A right pain. So glad to get rid of the old pads, whatever make they are!
Found I've got a tube of this Mintex Ceratec:
Any good? Cheers, Greg
Post #501577 14th Jan 2019 9:57pm
GGDR
Punches arrived, as did the pads and sensors.
Went for Greenstuff pads in the end. Shopped around and got a best price from a place called bearmach. Arrived next day so all good there, recommended.
Planning to do it over the weekend, to be prudent I WD40'd the pins this morning, I even gave them a test tap and seemed to move.
Fingers crossed I don't have pin/caliper corrosion issues like many others have had.
. Cheers, Greg
Post #501995 18th Jan 2019 1:58pm
GGDR
Ok Drivers side done:
In hindsight I should have ordered new clips. Just for aesthetics.
Pin-wise, I had a little trouble with the centre bolt, but the two outer pins came out easy.
I also didn't realise there was only one wear sensor - on the NS.
Having ordered two, I now have a spare!
One side, taking my time including jacking , wheel off and setting out tools to cleaned up, wheel back on:
1 hour 10 mins.
(that's with no real pin trouble)
After lunch: passenger side.
Smile Cheers, Greg
Post #502105 19th Jan 2019 1:40pm
GGDR
Both sides done now:
greased in the right places, wear sensor done, wheel nuts torqued.
All good, no snags and a quick job at an hour a side roughly.
Many thanks for tips.
And Northernmonkeyjones' Wiki a great help.
New onto to the next job Shocked
. Cheers, Greg
Post #502128 19th Jan 2019 5:18pm
Baltic Blue
Thumbs Up Thumbs Up
I bet it seemed easy after the EGR sensor job Rolling with laughter
Post #502132 19th Jan 2019 5:38pm
Page 3 of 3 <123
