Home > For Sale & Wanted > SOLD: Aftermarket Fixed L322 Side Steps
duckworthparts
Site Sponsor
I have a set of
£225.00 including postage. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #501665 15th Jan 2019 4:01pm
Nick591
Hi Dan,
I'm interested. Does 'aftermarket' mean not LR? If so what make are they and can you pm me some pix? I have heard that some people fitting non-OEM side steps have had trouble with the accuracy of the fit. Do you thonk that is likely with these?
Does this sale include front mudflaps? My RR had OEM side steps when I bought it but recently the NS one failed due to corrosion and I had to remove both sides but the related front mudflaps are still fitted.
Thanks, Nick Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #502034 18th Jan 2019 7:48pm
I wouldn't worry too much about accuracy of fit with aftermarket steps, with considered use of 8mm ss washers it is quite easy to overcome any inaccuracies. I fitted a pair and found that although not fully accurate they are surprisingly adjustable such that a well aligned fit can be achieved without too much trouble.
Post #502038 18th Jan 2019 8:52pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Hi niceday, does this apply to all the kits for sale on eBay? Some are £130-ish, some are nearer £300, and in the pictures I can't see any difference!
Post #502186 20th Jan 2019 12:40am
I have a feeling most eBay side steps will need a degree of adjustment to fit absolutely true. I got my set from eBay and there is really nothing wrong with them, certainly do the job, I stand on them regularly.
I really can't understand why the mounting brackets are not quite right, after all the cars are made using accurate jigs so I would expect them to be all the same. It can't be beyond aftermarket manufactures to make a correct set of mounting brackets, try them, then replicate but it seems it is.
I did contact a reputable installer of such steps and it seems it is generally acccepted that a liberal use of washers is required for fitting to most vehicle makes.
Fitting is straightforward, all the tapped holes are in place on the car, m8 and m6, it's just a case of finding them, they are generally covered in tape and sprayed over with something resembling stone chip.
LR even prefit the 3 bolts in the back of the drivers side sill as you wouldn't be able to fit bolts without removing the suspension air receiver otherwise. All you need to do is screw back the bolts and hang the brackets on.
Adjustment of the brackets up and down is simply a case of adding stainless steel washers between the top of the bracket and the car frame to achieve the desired height.
To get a good fit you just need a bag of m8 washers 2.0mm and 1.5mm thick.
More washers makes the outer edge of the bracket rise, less washers makes it go down.
Simply a case of adding and subtracting washers until you get the steps to line up with the sill and then tighten everything up. Thumbs Up
Post #502229 20th Jan 2019 6:32pm
Cappo
Thanks for that, much appreciated!
My previous L322 had them already but I've just put a deposit on another Cool which doesn't, so I'll be looking to fit some. As well as looks, we have elderly parents/inlaws who just can't get in without a leg-up!
Post #502248 20th Jan 2019 10:04pm
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
Haha, didn't find out about the "washers" until I'd fitted the step and it was about an inch lower than the fitting to sit in with the mudguard lol. Off to B&Q for 20 washers, and an hour or so later, 6 washers on the front and it was level. Would suggest getting a 40 / 45mm M8 to accomodate the extra washers (if you don't already have a long bolt)
Post #502257 20th Jan 2019 11:05pm
duckworthparts
Site Sponsor
Bump £185.00 You can paypal direct using - www.paypal.me/duckworthparts
Post #502513 23rd Jan 2019 11:27am
Nick591
Hi Dan,
Per my call just now I will take those off your hands at £185 posted.
I will pm you with address
thanks, Nick Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #502539 23rd Jan 2019 4:30pm
