Home > Technical (L322) > Dash cluster replacment cause loss of Air Susp ?
Patz L322
Australia 2003 Range Rover Vogue 4.4 V8 Causeway Grey
G’day all
Gra8 site and I would like to pick some brains please . Ok I have a 2003 V8 Vogue Australia, The Dash Cluster had burnt out lcds so had a new one fitted, and the dash lcds are all new and reads perfectly. The thing is it is showing Air Suspension Fault and wont clear (was fine before) the specialist is saying that they think it needs codes resetting. Any ideas Please .Gra8 team but it has been over two weeks , Cheers all
update They seem to think it's not talking to the new dash cluster ?
This is from the Range Rover Guys ( it's one of those we have never seen anything like it .it's got them scratching there heads ) it's been to two Land Range Rover w/shops for code reads Need more time
Post #502059 19th Jan 2019 1:18am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Not sure from reading if you have just had the LCD repaired or fitted a brand new cluster?
If you have just had the pixels repaired then I assume you've done the obvious and checked all the cluster connections are seated fine and have done the steering reset - wheel full lock to left, full lock to right? If so you might have a problem with the BCM.
If you have fitted a new cluster was it a new one or second hand? I know from bitter experience they need paired to the bcm as the instrument cluster is VIN coded and this will need Landrover software (I think Testbook does it, but not sure) but it definitely isn't a straight swap out/swap in. If the tamper dot on the trip display is showing or the VIN on the cluster (hidden menu, search Wiki) doesn't match the car VIN and the milage on the display isn't what you expect it to be then its not communicating with the car and will need coded. In the end when I had problems I had to get the original cluster fixed Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #502312 21st Jan 2019 7:34pm
Patz L322
A big Thank you Mate Cool i will let them know ,strange thing they said somthing like that and they are a land rover specalist , Thanks again Pat
Post #502363 22nd Jan 2019 7:46am
