![]() | Home > Technical (L322) > Windscreen wipers parking mid screen after wash |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
When I had my issues, which you prob read, it was inside the wiper motor where it told the ecu it was at the down position that was at fault. Needed new motor. It affected all wiper positions though, in strange ways. 2011 Range Rover Vogue SE 4.4 TDV8
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1866 ![]() ![]() |
It will need a new motor. Fairly common for them to do that, unfortunately |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 ![]() ![]() |
Balls |
You have to buy it with all the wiper linkage....new anyway...... but you can just put the new motor on your old linkage....
Ah that sounds a bit less hassle if I find a decent breaker. at least its all not rivetted together.
And it's back to doing the same thing...other wipe modes work but taking more sweeps which I presume to be this non-servicable park switch?
Just an update in case anyone searches the thread titles (like I did) for dickey wipers.....
