Home > Technical (L322) > Satnav screen gone off...
Andy
Took the tv in motion lead out today, with a view to fitting the Freeview box. Didn't realise the time, so I plugged the existing loom back into the box until I have more time to do the job .
Now I have no display. The screen is doing something as it turns black and you can see it's illuminated in the dark. Everything else works fine.
Did a Google search and pulled Fuse 49 for 15 mins, but still no display
Any ideas guys? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #53075 5th Mar 2011 7:31pm
put the tv in motion lead back in to see if that makes a difference....or battery disconnection for a reboot.. ... - .- -.
Post #53096 5th Mar 2011 8:50pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Do you have the Sat nav LED lit up in the boot? 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #53122 5th Mar 2011 11:36pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Did you fix this Noddy? If it's still dead then you may need to update the software... My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #53200 6th Mar 2011 6:58pm
Andy
Haven't had chance to look at it yet. Off for 4 days as of tomorrow, so I'll have another go then. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #53239 6th Mar 2011 11:00pm
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Disconnect battery and leave off for a few mins and touch both leads together to fully discharge residulal power in ecus then connect up usually solves lots of niggley communication faults 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #53240 6th Mar 2011 11:05pm
Andy
Disconnected the battery but made no difference.
I did wiggle the plugs in the back of the car and the screen came on! Further investigation revealed one of the terminals had slight corrosion. A quick clean and its as good as new.
Just need to work out how to get the Freeview working now! Big Cry 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #53642 9th Mar 2011 11:45am
