Home > Technical (L322) > ZF5Hp 24 transmission issues in 2002 4.4 V8
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
So slight wobble when pulling away gently, like the transmission is missing the gear 1 to 2 or the engine is stalling. Tends to happen when it’s cold.
Also on a steep incline it will slip into neutral and I’ll have to roll back down to the flat to find a gear then arrack the incline with speed.
Could this be low oil??
Post #503523 1st Feb 2019 12:37am
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
That would be my first guess given what you describe. It’s also the easiest first step in the diagnosis/rectification process.
Do you know if the vehicle has ever had its transmission fluid changed? If not, then given the age and likely mileage, I’d get the oil and filter changed. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #503579 1st Feb 2019 2:59pm
ohuntsman
Hiya, thanks for replying I did the oil and filter a year ago so I’ll give it a top up!
Post #503766 3rd Feb 2019 4:02am
