![]() | Home > Technical (L322) > Rear lights on all the time |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Brake Light Switch:
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 ![]() ![]() ![]() |
Cheers Joe. Any idea where the brake light switch is? I don’t have an LCM module as mine is a 2011 model so lights go through BCM I believe. 2011 RR Autobiography 4.4 TDV8 |
Up the top and behind the brake pedal arm - well that is where it was on my TD6, easier access if you remove the trim panel below the dash / above the pedals .
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
To me, those look like aftermarket 'black' lamp units. If so, they're really designed to operate with earlier (pre 2010 facelift) cars, with the added circuit board.
Well spotted spooky, advertised as "This item will fit all Range Rover L322 models from 2002 - 2013 ( 2002 - 2009 require mount and wiring modification)
