Home > Technical (L322) > Check your damper wiring
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Just had and adaptive damping fault jump up on dashboard , wouldn't clear down so oh no I thought , pop the bonnet and start looking to find a snapped wire on drivers side , rubbed through on wing top , bit of solder and heatshrink and all sorted but for good measure taped both sides up with a bit of extra insulation and lifted wires up slightly .
Post #504063 5th Feb 2019 6:41pm
mjdronfield
This is a bit of a known fault. Land Rover supply a kit to fix I believe, but essentially just does what you have done.
Think the wires are a bit brittle. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #504065 5th Feb 2019 6:44pm
mjdronfield
https://www.fullfatrr.com/forum/topic35724...mics+fault
https://www.fullfatrr.com/forum/topic22949...mics+fault
https://www.fullfatrr.com/forum/topic44948...mics+fault
Bit more info Thumbs Up 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #504067 5th Feb 2019 6:49pm
matthews
Obviously typed my search wrong in the search box as it came up with no results , hence the investigation and op Very Happy
Post #504083 5th Feb 2019 9:37pm
