Home > Technical (L322) > dash lighting ecu
jk3528
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
dash lighting ecu
ok so still got the warning light issues even if I unplug everything from the I bus except the dash and light ecu
so can only think its one of these causing the I bus fault
if I change the light ecu do I need to put the chassis number in and if so can I do this with the iid tool?
Post #503803 3rd Feb 2019 2:27pm
If you mean the LCM, from memory most people have just been able to do a straight swap.
Worth having a look inside to check for any physical damage / water ingress etc. It is a little difficult getting the PCB out without destroying the case! .
Post #503814 3rd Feb 2019 4:30pm
jk3528
What about the dash ?
I did try another lcm but no change
But I also changed the dash but that had no effect but have been told that if you don’t put the chassis number in it won’t talk to anything
Post #503836 3rd Feb 2019 6:28pm
