Home > Technical (L322) > Can a crap battery throw these faults? (12.09V)
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
As you know I got a car on Sunday and rather tan posta thread for each fault, I thought it could be the battery.
Just been for a short drive and 30 miles later its reading 12.09v
I have:
ABS valve relay fault (0X000E
Air suspension CAN error (that might be me jacking it up this morning)
Transfer case-battery under voltage)-(0X5212)
Could the low voltage be doing these?
Post #504027 5th Feb 2019 3:52pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Charge the battery, clear the codes, see if they come back.
Post #504028 5th Feb 2019 3:58pm
philip1972
good plan, but I dont have a charger!!!
It looks really old and undersized for the space too, so I have ordered a new one, arriving tomorrow Thumbs Up
Post #504029 5th Feb 2019 4:15pm
do you have a L322 or L405??????
Post #504032 5th Feb 2019 4:30pm
philip1972
L322, 2004 V8 Vogue with LPG Thumbs Up
Post #504033 5th Feb 2019 4:32pm
you have a L405 2014 showing in your car profile..
Post #504037 5th Feb 2019 4:37pm
philip1972
Oh Censored .
I will change now. I did have use of one a while back so probably relates to that. Thumbs Up
Post #504038 5th Feb 2019 4:39pm
Paul thornton
I got loads of can faults on mine when the battery was fooked.
Basically when you crank the car the starter sucks all the available voltage hence the various ecu 's loose communications and flag up can (communication) errors.
Post #504072 5th Feb 2019 7:33pm
