Home > Technical (L322) > Jacking up on the control arm?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I have read that lots of people do it, as there is less suspension travel therefore easier to get the wheel off the floor.
Do you do it?
And which end of the control arm...the inner or the outer which is right by the wheel?
Cheers Thumbs Up
Post #503987 5th Feb 2019 8:46am
I always use the proper jacking points and use a hack that lifts high enough
Post #504005 5th Feb 2019 11:49am
Baltic Blue
+1,
But I then put an axle stand under the inner end once the wheel is off as a “just in case” whilst I am working.
Post #504008 5th Feb 2019 12:47pm
philip1972
Thanks all Thumbs Up
Post #504009 5th Feb 2019 12:51pm
