AIR CON HOW to DISABLE L322 2006 V8 | |
I am about to replace cam cover seals and the manual says to degas system and remove AC pipe over cam cover.
Does anyone know how to cut the power supply to AC unit (other than disconnecting the battery)
I want to remove either the AC fuses or relay so the AC has no power whilst I am working on car as I will have to drive it to see if the seals are ok after install and I definitely dont want the AC unit accidentally turned on with the pipe removed.
I have found 2 AC fuses in the glove compartment but I cannot find the AC relay and not sure which is best to remove to disable the AC unit completely.
