Home > Technical (L322) > L322 ABS relay location
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Can anyone tell me where the ABS is exactly?
Struggling despite Googles help!
Post #504021 5th Feb 2019 3:19pm
uzp315
Assuming from the title you are looking for the relay and not anything else. All I can offer is that on my 3.6 there is a large black plastic box at the front o/s under the bonnet. This contains a large number of relays. Not sure if the ABS one is in there though, or whether you would find this box on any other variants than the 3.6 dieseasel.
Post #504558 9th Feb 2019 10:13am
Dolphinboy
Looking at the engine from the front (facing rear) it is a box with lots of hard steel pipes coming out of it at the rear right of the engine bay, near the windscreen. There is a large wire going into the lower right (pax) side (looking at it from front) which should be taken off and examined as its a water trap and corrodes the pins. A good clean up can work wonders.
What’s your fault?
Post #504571 9th Feb 2019 11:48am
