![]() | Home > Technical (L322) > Check your damper wiring |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
This is a bit of a known fault. Land Rover supply a kit to fix I believe, but essentially just does what you have done.
https://www.fullfatrr.com/forum/topic35724...mics+fault
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Obviously typed my search wrong in the search box as it came up with no results , hence the investigation and op |
