![]() | Home > Technical (L322) > Intermittent Engine Fault - help! |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773
Sounds more like throttle potentiometer (throttle pedal) than throttle body, although the fault it occurs while using cruise control then the throttle butterfly could be being operated to increase exhaust gas flow through the EGR valve. |
| Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32
Thanks - butterfly was mentioned!
| cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 76
Hi Slaav, check the butterfly flap in the housing.........my 11 plate 4.4 tdv8 was gunged up with loads of c |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
^ +1 with GraemeS and cozzy on this. Mine had a lot of gunge when I changed the short plenum hoses. Also clean the MAP sensor, just behind the throttle body on top of the plenum.
I would do some experimenting with the brake and accelerator pedals to see if the accelerator can be made to misbehave, possibly with a different fault code that might assist in finding the culprit. |
