Home > Technical (L322) > 2007 TDV8 rear axle absorber / Mass Damper
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
The mass damper (TVG500010) on my rear differential (E-diff) is looking rather sorry for itself. Instead of going through the hassle of removal, rust prep., Paint etc. I figured I'd just order a new one. Until I found out they were £300 each..
The absorber/mass damper for the 4.4 TDV8 (LR025818 ) is however just £30.
Anyone know if these are similar? Can I use the later version?
3.6 TDV8
4.4 TDV8
[/img] 2007 L322 3.6 TDV8 Stornoway
Post #504349 7th Feb 2019 6:36pm
Landmark
Hi did you ever find out if these were the same. I'm now in same boat and wanting to change.
Post #663971 12th May 2023 6:34pm
