Home > In Car Electronics (L322) > Streaming videos from iPhone
weetabix86
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Barolo Black
Is there any way to stream videos from an iPhone to the TVs in an L322 through the composite/AV connection? Have found an adaptor for the iPhone but wanted to ensure it was a possibility before I spent the money.
Post #504464 8th Feb 2019 3:10pm
Jpboost
After some playing about, I've got a Google chromecast streaming to the rear screens in mine via an HDMI -> composite converter.
But it's a bit of pain to setup, mostly as chromecast needs to be on the same wifi as the phone. So necessitates using your phone as a wifi hotspot, and then configuring the Chromecast to work from that.
I'm using an android phone, (and haven't used anything apple for quite a while), but if the casting functionality is the same, I don't see why it couldn't work on an iphone.
Of course if there's a converter from iphone to composite, then that would be much simpler (if it works)
Cheers
Jon
Post #504482 8th Feb 2019 4:32pm
I did it many years ago with an old iPhone - with the old wide connector you could get a cable with composite (amalogue) output.
As above, everything 9s digital these days so something like an hdmi > composite converter will be needed and you can use an Apple TV
Money would be better spent on iPads and forget about the car screens IMHO
Post #504555 9th Feb 2019 9:27am
