Home > Technical (L322) > TDV8 3.6 battery questions
Tight777
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Had a few odd errors crop up intermittently and after fitting new pads (started the car a few times then switched off)
It was flat so hopping the battery is dying and causing the errors.
2007 3.6 TDV8
Was it originally supplied with a AGM battery as at the moment there’s a Banner AGM 105ah fitted
Post #504486 8th Feb 2019 4:43pm
dolph34
To my knowledge the 2007 had a ' normal ' non AGM battery Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #504487 8th Feb 2019 4:45pm
Tight777
Thanks that’s what I thought, when trying to buy a new one they just ask what’s fitted.
Post #504490 8th Feb 2019 5:14pm
Tight777
Any suggestions as to the correct battery?
Post #504754 10th Feb 2019 9:33pm
dolph34
I think I had a 020 in mine. Just checked , i did Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #504757 10th Feb 2019 10:00pm
have a search on here, there are plenty of threads on what size fits.
Form memory I think that the 020 was a tight fit and may need, trimming to get it in easily. Now here's the rub, check your alternator voltages before you just bung a new battery in, if its not charging right it will fry the new battery pretty quickly.
The Bosch 020 S5 was the preferred one for a while but they didn't seem to last long on several occasions. the last few times Ive swapped batteries in the FF and the D4 I've put in a get LR one. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #504767 10th Feb 2019 11:18pm
Mikey
Exide EA1000 Thumbs Up
Post #504780 11th Feb 2019 7:37am
+1
2007 seemed a particularly bad year for alternators on TDV8's - there's been a disproportionately high failure rate
Post #504781 11th Feb 2019 9:17am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
The full size battery for the L322 MY 07 is 020. I fitted myself a 020 Bosch S5015 12v 110Ah' It was a tight fit and physically larger than the on I took out that I think the AA had fitted several years previously.
I don't know what size battery these facelift L322's came with ex-factory?
Post #504782 11th Feb 2019 9:26am
