![]() | Home > Maintenance & Mods (L322) > Rear Diff Oil refill level on ETM Diff 2006 AJV8 Help |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2732 ![]() ![]() |
Mine has the same diff and the owners manual states 1.6L dry fill, 1.55L refill after drain. I put in 1.6L when I swapped the open diff for an e-diff 2 years ago. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
GraemeS, was it easy or not so to swap differentials? 2012 TDV8 Black Edition
The diffs are heavy - 2 people struggled with jacks but we got there. A hoist with an appropriate equipment jack would have made the task much easier.
thank you GraemeS, |
Blue Hornet Member Since: 25 Sep 2018 Location: Sawtell Posts: 17 ![]() ![]() ![]() |
Thanks Graeme yesterday I finished the oil change on the front and rear diffs and transfer case.
Are you sure that you have an ediff?
Hi Graeme thank you for help after your question whether I have an Ediff I went and had a good look at my diff and its not an Ediff its the Open diff so thanks for your intuition.
No harm in using ediff oil in an open diff other than the hole in your pocket. |
