![]() | Home > Technical (L322) > TDV8 4.4 Coolant temperature sensor location |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
item number 5,
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 55 ![]() ![]() ![]() |
Many thanks, so that's inlet manifold off first, oh great!!! |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
If you are having problems with both the oil level sensor and the water temperature sensor, I wouldn’t rule out some form of “electrical “ issue before I started changing sensors.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2754 ![]() ![]() |
Fuse 5E (#5 in the main engine bay fuse panel, not the auxiliary fuse panel in the same box) supplies the oil sensor but also several other components so is unlikely to be the cause. The coolant temp sensor is not supplied with power from a fuse.
