Home > Technical (L322) > Deployable Steps - User Guide
millerj90
I’ve tried several searches, and even Google cant help..
Does anybody have a copy of the user guide for the L322 Deployable steps?
Specifically, I’m looking for instructions on how to remove them; as if for jacking, thus allowing me to clean and hopefully properly lubricate them.
I know you have to remove a couple of Allen screws, and I have the key to do that. The problem is that I’m not sure which ones to remove. I can see two per bracket. One on the moveable section, which I think are the ones to remove, and one on the fixed section.
Any clarification of a manual would be most helpful.
Many thanks.
Post #504934 12th Feb 2019 7:45pm
have you tried topix?
Post #504937 12th Feb 2019 7:51pm
millerj90
Yes Stan, I did try that.
I don’t have a user account, I’m not a dealer and tells me to contact Customer Services.
It does advise me that user manuals are available from the Land Rover JLR User Manual site. But this only goes back to 2016 and then helpfully advises you to go to Topix!
Post #504941 12th Feb 2019 7:59pm
http://www.fullfatrr.com/gallery/albums/us...RRVDSS.pdf
this is the pdf fitting instructions so you'll be able to see whats involved..
Post #504942 12th Feb 2019 8:11pm
Baltic Blue
Didn’t NMJ include a copy in his wiki topic for fitting ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #504944 12th Feb 2019 8:11pm
probably Very Happy Thumbs Up
Post #504945 12th Feb 2019 8:13pm
millerj90
Stan
Many thanks, I have the fitting instructions. But I’m still confused as to what screws need to be removed for "jacking access"
Post #504950 12th Feb 2019 8:48pm
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Edit:
To properly lubricate I would recommend ro remove the entire assembly, remove drive motor from assembly, use oil of preference, not grease or water dispersant, and thoroughly lubricate all movable joints while moving the hinges. These have press-fit soft metal bushings, and no grease will penetrate into these surfaces, "Multi purpose penetrating oil" usually last only for a very short period.
You'll feel a difference when all parts are moving freely. You'd probably also notice excessive play on the driver door side hinge joints. This method will also allow you to properly set the wedge upon re-assembly. 2007 L322 3.6 TDV8 Stornoway
Post #504958 12th Feb 2019 9:37pm
Fig 119 on stans fitting instructions, look at the LHS where the hinge meets the step, the screw/bolt is illustrated as the small dome underneath... There are two on each hinge so 4 per side... Thumbs Up
Post #504960 12th Feb 2019 9:38pm
millerj90
Many thanks to you all. I think I’ve got it now, and even better, some tips on proper lubrication.
Post #504965 12th Feb 2019 9:55pm
I would suggest you soak the bolts multiple times with WD40 for some days before you attempt removal and only use a good quality allen key socket to move the bolts as they are prone to rounding off being allen keys! I changed all of mine to stainless torq bolts and greased them liberally before installation... Thumbs Up
Post #504967 12th Feb 2019 10:05pm
thats a good tip craig.. Thumbs Up
Post #504968 12th Feb 2019 10:06pm
Im not just a pretty face Stan... Whistle
Post #504969 12th Feb 2019 10:08pm
Laughing Thumbs Up
Post #504970 12th Feb 2019 10:17pm
millerj90
Many thanks Craig
Wise words Thumbs Up
Post #504975 12th Feb 2019 10:32pm
