Home > Maintenance & Mods (L322) > Lower Outer Door Seals.....
cozzy
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Hi people, I need part numbers for both front OUTER lower seals for my 2011 FFRR 4.4 tdv8. It's the ones at the bottom of the front doors (they have an outer rubber flap) for want of a better description !!
I've ordered numerous seals and all have been wrong ! Help !! Embarassed
Thanks in advance,
Cozzy. Thumbs Up
Post #505247 15th Feb 2019 6:01pm
dirtymonkey38
Leaking or road noise? I get road noise that sounds like its coming from the rear passenger door. id be interested in part numbers too 2011 RR Autobiography 4.4 TDV8
Post #505280 15th Feb 2019 8:55pm
cozzy
Hi Dirtmonkey. my ones have a small tear in them......hence why I need replacements ! Help please people. Bow down
Regards ,
Cozzy.
Post #505395 16th Feb 2019 7:51pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Do you recognise the seals in the following diagram, or are the ones labelled in red the ones that you've already purchased and discovered are not correct?
If not showing here, I'd be asking Dan @ Duckworths for some help in identifying and supplying the correct part.
 Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #505397 16th Feb 2019 8:45pm
could be part oft eh door moulding, but the one shown under that in the MC pic(24692a)
is Part no LR022937
not sure if that is the right one though...... it could come as part of the bottom door moulding There is nothing that can't be fixed with a hammer😜😜
Post #505406 16th Feb 2019 9:59pm
cozzy
Hi , its clipped on to the lower plastic painted trim on the bottom of the doors.....I think you could be spot on Northernmonkeyjones . I guess I will have to go to the main dealers.
Kind regards,
Cozzy.
Post #506137 23rd Feb 2019 9:37pm
cozzy
Hi Guys and girls, just a quick update.
The seal I require is part of the bottom door moulding and can only be purchased as a complete unit apparently ! Great Censored
Just to rub salt into the already inflamed cut, they come ( the plastic part that is) Unpainted Big Cry .
Cost each before painting Is £120.74 Inc of Vat.
Post #508904 16th Mar 2019 1:51pm
