Home > Technical (L322) > L322 non start and codes PO251, PO116
edward19
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi All
I'm having a few problems with my recently acquired 2011 L322 which (among other things I've posted on this forum) is a non runner. I have restricted performance displayed on the dash and the codes 'pending' in the ECU are
PO251 Injector Pump fuel metering Control 'A'
PO116 Engine coolant Temperature Sensor 1 Circuit range / performance
However oddly no confirmed and stored codes (this could be me deleting them, opps)
The car was a stolen recovered and was very low on diesel, showing a range of 30 miles. Therefore I've added some to take it out of the reserve.
Steps taken
- I plugged in my delphi scanner on OBD mode and determined
Fuel pressure - 1690 KPA or 16.9 bar
Coolant temperature reading 215 degrees at cold.
As the fuel pressure seemed low, given the code above and the non start I removed the high pressure pump and sent if off for diagnosis. Today I was told it tested fine, which I'm somewhat surprised about.
I also managed to start the car by cranking and squirting easy start down both intakes. Just enough for it to fire up and then die after stopping, so I certainly have a fuel pressure issue. Also I cracked open one of the unions on the fuel rail and have some fuel present.
Any advice would be great.
Thanks
Post #505394 16th Feb 2019 7:47pm
there is usually a metering valve on the fuel pump, this failed on my 2010 D4, unfortunately on that it was part of the pump so it was a whole new pump!! not sure if its a separate item on the 4.4 tho. worth asking for it to be looked at as well.
edit... seems to be a separate item on the 4.4, bolts onto the HP pump, would throw up that fuel metering fault if it was duff I reckon.
part no Thumbs Up LR023169 There is nothing that can't be fixed with a hammer😜😜
Post #505405 16th Feb 2019 9:46pm
edward19
non start
Hi
Thanks for the info. I think this does bolt onto the fuel pump and wonder if having sent the whole unit to a diesel specialist they would have checked this. They have suggested putting the pump back on the car and seeing what happens!! Seems a bit odd
Post #505414 16th Feb 2019 11:01pm
depends whatbthey tested.
if the pump is ok then it might be worth getting this swapped out before refitting the pump There is nothing that can't be fixed with a hammer😜😜
Post #505424 16th Feb 2019 11:54pm
edward19
It runs
Hi
I've had the fuel pump back and after clearing the metering code and cranking the vehicle runs!!, phew. Would anyone be able to send a picture of the battery in a 4.4 and ecu on a L322. I just want to check I'm not missing any covers etc.
Post #505956 21st Feb 2019 9:38pm
